Pc Build Help Needed
Solved by BahnStormer,
17 hours ago, Hinjima said:I will still definitely recommend the 7600 non X. Its faster than the 8400F and 8600G ( Not by a lot though )
for most gaming uses, the 7600 (even the non-X) is a good bit faster due the L3 cache being double the size...
derekchan ·
Posted in New Builds and Planning4 -
1
5
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting6 -
DavidPatrascu ·
Posted in General Discussion9
play_circle_filled
Latest From ShortCircuit:
