Help
Go to solution Solved by Millios,
1 minute ago, FroZen said:
I am thinking about purchasing myself a new graphics card for Christmas, I am thinking about getting a 3090 (500 usd) or a 6950xt (450 usd) the 3090 is a zotac trinity and the 6950xt is just the reference edition if someone could help me decide between the two it would be incredibly helpful I’m mainly just going to use it for ultra wide 1440p gaming for games like cyberpunk 2077, r6 siege, elden ring and some other games I’m not sure if the 3090 is worth the extra 50 for ray tracing and dlss
Its worth it if you want ray tracing.
If not the rx 6950xt is better as it performs better (slightly but still better) than a 3090 TI
https://linustechtips.com/topic/1593306-help/
I edit my posts for so if you saw a typo.... no you didn't, you are just crazy
https://linustechtips.com/topic/1593306-help/#findComment-16603267
