Peltier Cooler
Solved by Eigenvektor,
2 minutes ago, ulookuglynoob said:so I thought that maybe I could try using a Peltier cooler with my aio to cool my cpu.
Peltier is not an effective solution for a CPU cooler. Due to inefficiency, the cooling you get on one side is offset by more heat on the other side that you now need to somehow get rid of. They also require a lot of power.
They only really make sense in situations where you can't have moving parts and are size constrained, but power draw is not an issue
