I Need help
By
Nightclaw05
in Troubleshooting
in Troubleshooting
Solved by Spotty,
That's normal the first time you turn the PC on. If you shut down and turn it back on does it still take a long time to boot? If it still takes a long time to boot you should check if there is a BIOS update available for your motherboard.
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
Posted in Servers, NAS, and Home Lab1
play_circle_filled
Latest From ShortCircuit:
