The 120mm fan goes inside the back of that case for an exhaust fan. Add this set of RAM to that build.
https://www.newegg.com/g-skill-64gb-ddr5-6000/p/N82E16820374518
G.Skill Flare X5 DDR5-6000 64GB (2x32GB) CL30 $189.99 ETA Date: 12/12/2024
PCPartPicker Part List
CPU: *AMD Ryzen 9 7900X 4.7 GHz 12-Core Processor  ($309.00 @ Amazon)
CPU Cooler: *ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler  ($29.99 @ Amazon)
Motherboard: *MSI MAG B650 TOMAHAWK WIFI ATX AM5 Motherboard  ($179.99 @ MSI)
Memory: *Corsair Vengeance 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory  ($220.99 @ Amazon)
Storage: *Samsung 990 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($159.99 @ Amazon)
Video Card: *Gigabyte WINDFORCE OC GeForce RTX 4070 Ti SUPER 16 GB Video Card  ($799.99 @ Amazon)
Case: *Fractal Design Focus 2 ATX Mid Tower Case  ($69.99 @ B&H)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Newegg)
Operating System: *Microsoft Windows 11 Home OEM - DVD 64-bit  ($119.99 @ Amazon)
Case Fan: *ARCTIC P12 PWM PST 56.3 CFM 120 mm Fan  ($9.99 @ Amazon)
Monitor: *Dell G2725D 27.0" 2560 x 1440 180 Hz Monitor  ($149.99 @ Dell Technologies)
Total: $2159.90
Generated by PCPartPicker 2024-12-06 10:30 EST-0500
https://linustechtips.com/topic/1591518-build-ideas/#findComment-16591059
7 hours ago, alan93 said:
What AMD build would everyone recommend for a PC? I want to mainly use it for Maya and other 3D software and be able to play games like Escape From Tarkov, FF14 online, and those types of games? my budget would be between $2,000-$2,500 USD.
CPU: AMD Ryzen 9 9900X 4.4 GHz 12-Core Processor  ($369.00 @ Amazon)
CPU Cooler: ARCTIC Liquid Freezer III 360 A-RGB 48.82 CFM Liquid CPU Cooler  ($107.79 @ Amazon)
Motherboard: Gigabyte X870 EAGLE WIFI7 ATX AM5 Motherboard  ($199.99 @ B&H)
Memory: G.Skill Ripjaws S5 64 GB (2 x 32 GB) DDR5-6400 CL32 Memory  ($194.99 @ Amazon)
Storage: Western Digital WD_Black SN850X 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($148.00 @ iBUYPOWER)
Video Card: Asus TUF GAMING OC GeForce RTX 4080 SUPER 16 GB Video Card  ($1099.99 @ Amazon)
Case: Lian Li LANCOOL 216 RGB ATX Mid Tower Case  ($99.99 @ Amazon)
Power Supply: Corsair RM1000e (2023) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($159.99 @ Amazon)
Operating System: Microsoft Windows 11 Home OEM - DVD 64-bit  ($119.99 @ Amazon)
Total: $2499.73
Generated by PCPartPicker 2024-12-06 11:36 EST-0500
Do you need a monitor?
To be an expert is to know more about less.
  • 2014 Build --> FX 8350 4.7GHz {} ASRock Fatal1ty 990FX Killer {} Reference GTX 980 4GB {} 2x4GB 1866MHz HyperX {} Seagate 2TB 7200rpm {} 840 EVO 120GB {} XFX PRO850W {} Noctua NH D14 {} Fractal Define R4 White Windowed
  • 2018 Build --> Ryzen 7 2700X {} ASRock Fatal1ty X470 Gaming K4 {} Gigabyte RTX 2070 8GB {} 2x8GB HX Fury 3200MHz {} Toshiba P300 2TB {} Kingston 480GB A1000 {} Corsair RM750W {} Enermax LIQMAX II 240 {} Fractal Focus G
  • 2021 Build --> Ryzen 9 5900X {} ASUS ROG Strix X570-F GAMING {} ASUS GeForce RTX 3080Ti ROG STRIX OC {} Gigabyte AORUS RGB DDR4 32GB {} Kingston KC2500 M.2 2280 NVMe 2TB {} Seasonic FOCUS GX-1000 {} ASUS ROG Ryujin 240 AIO {} NYXT H710i
  • 2026 Build --> Ryzen 9 9950X3D {} ASUS ROG CROSSHAIR X870E HERO {} ASUS GeForce RTX 5090 32GB ASTRAL LC {} G.Skill TridentZ Royal Neo RGB Silver DDR5 CL28 6000MHz 2x16GB {} Samsung SSD 4TB 9100 PRO M.2 {} Seasonic 1600W PRIME TX Noctua Edition {} Fractal Lumen S36 V2 RGB 360mm AIO {} Fractal Design North XL Charcoal
https://linustechtips.com/topic/1591518-build-ideas/#findComment-16591115
Total: $2499.73
Na I got a monitor and everything else. My Intel system bout to run out on warranty on everything so just looking to get idea is all.
https://linustechtips.com/topic/1591518-build-ideas/#findComment-16593923
