Need A Motherboard
Go to solution Solved by Penpilot,
please avoid repeat posts but yes that would work.
Budget (including currency): 250
Country: Ireland/UK
Games, programs or workloads that it will be used for:
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):  Hey, need a new a motherboard that works with DDR4 Ram and PCIE 4 SSD, and has to have wifi along with working with an AMD chip I have in mind a used Gigabyte B550 AORUS ELITE AX V2 ATX AM4 Motherboard. Would that be fine or any other suggestions please and thanks
https://linustechtips.com/topic/1590961-need-a-motherboard/
