Posting this again:
My pc has been acting up ever since I got back from summer vacation. I had no issues previous to my trip (13/6 - 15/8) but upon my return I was met with a plethora of problems surrounding my computer. These issues are only apparent while playing games and barely overlap from game to game.
The first issue I noticed was that, l specifically when playing Overwatch 2, my character will at seemingly random times move spasmically and activate random inputs. After this I will always be disconnected from the server and any other program on the pc seems to lose internet connection for a few seconds before everything reconnects. During this I am disconnected from any calls and spotify stops playing music.
The second issue is that while playinig Tom Clancy's Rainbow Six Seige my frames per second will drop from 200-300 to 50-60 for up to 30 seconds. Furthermore, at seemingly random times (possibly the same issue as on overwatch??) my game will freeze completely and the fps counter will display 1 or 0 and my GPU latency will start rising in tiny increments. This issue is resolved as soon as I tab out of the game and back in again.
I have brought my PC to a local workshop and they found no issues. I have also brought my PC to a friends house and tried it there, no issues. Lastly I have tried to use my friends monitor and once again the issues were not fixed. I've arrived at the conclusion that the problem is most likely related to my GPU or its connection to my screen. I have tried using different cables, different DP/HDMI sockets, I have reinstalled all my drivers as well as completely reset my pc, I have also switched the places of my ram sticks, flushed my DNS, renewed my IP, rebooted my router, tried a DDU run.
I can't access my PC currently so I will do my best to provide my specs.
I play on two monitors, my pc is self-built and around 1.5 years old.
GPU: 4070 ti
CPU: 13700k
Motherboard: MSI Pro Z690-A
RAM: Kingston Fury 64GB (2x32GB) DDR4 3200MHz CL 16 Beast
https://linustechtips.com/topic/1590830-strange-issues-please-help/
your connection to the server isn't stable causing your two issues, fps drop from non stable connection as long as you disconnect from the server, it can happen from your internet provider himself, you can call the, also check if the phone land line is working and can ring, even if you commect directly to the router, disconnect it then put it on a phone
