Hello,
I have a specific CPU optimization setup for gaming (Rainbow 6 Siege) where I use Process Lasso to limit all background processes (*) to just 2 logical cores (core 0 with hyperthreading enabled, so logical processors 0 and 1). The remaining 7 P-cores are assigned to the game, with the last of these also having hyperthreading (HT) enabled, so the game has access to 8 cores total as this is the best setup I have gotten with as little micro stutters as possible (without having to go into the bios and disable HT and the e cores every time I want to play a game). I have my E-cores not disabled but not set to any process during gaming since they can limit P-core speeds due to power draw limitations on my laptop but, system tasks have full access to all 32 logical processors (because I can't limit system tasks in Process Lasso). My TCC offset is set to 85C (so max CPU temp is 85C). My laptop is a Dell G15 5530 with i9 13900hx and 4060 mobile. The first core (logical processors 0 and 1) runs at max utilization during gaming due to handling all background tasks. Is this max utilization on core 0 harmful to my CPU? For context, this is an 8P 16E configuration. Thanks for your help in advance!
CPU Tune:
Intel® Turbo Boost Max Technology 3.0 - disabled
Processor Core IccMax - 142.50A (My way of limiting VID requests to 1.40V)
Turbo Boost Short Power Max - disabled
Turbo Boost Power Max - 191W (Stock Alienware Performance configuration)
Turbo Boost Power Time Window - 128 seconds
Locked P core ratio - 49x
Edit:
I want to rephrase my question: Is max utilization on core 0 for long periods of time (like couple hours straight every other day or something) going to damage the core over a long period of time (like over the span of a couple years).
Edited by Adrian F
Rephrased Question
https://linustechtips.com/topic/1589788-cpu-max-utilization-core-0-durability/
no it isnt
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
