help with ( LF 820e 43c & n solid capacitor ) solid capacitor
Hi all i have been trying to find ( LF 820e 43c & n solid capacitor ) but can not find them or better ones and sorry it is on ( gigabyte gtx 960 2gb windforce 3 fan video card ) any help would be good thank you   looks like one is leaking fluid from the bottom of the cap
you said youself that its a solid capacitor, solid means no fluid
so this isnt a leak and you shouldnt worry about it
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
