Basically my PC froze yesterday on the log in page. After resetting the white light on my MSI motherboard turned on indicating the VGA. I first thought my pcie slot was broken so I tried my 970 I had hanging around and it worked
Then I thought my GPU died however it worked on my friend's PC so it wasn't the GPU either
I'm 99% sure it's the PSU, it's a C tier gigabyteP650B I've had it since 2020, it works with my 970 for now. I came across two PSUs around the 100 euro mark
Seasonic GM g12 750w
Corsair RM750e
I'm almost certain the seasonic is b tier and the Corsair a tier, is there any significant difference between the two other than the one is semi modular and the other full modular
This will also be a step for a GPU upgrade in the future (rtx4080)
Note: with hwinfo I found out that my CPU is exceeding power limits during heavy load however that could just be my Motherboard I'm not sure if that's a PSU problem as well but alas
Specs:
I7-10700f
RX6700XT
32GB ram
MSI B460 PRO
2hdds
1sata ssd
1nvme
https://linustechtips.com/topic/1589420-psu-replacement/
The only major difference is how much power the 12v rails can hold for long periods of time without burning out
Gaming Rig:
Ryzen 7 7800x3D -30 Curve  | Thermalright Peerless Assassin 120 SE  |  ZOTAC GAMING GeForce RTX 4070 SUPER Twin Edge OC 12GB  | Patriot Viper Venom 16GB CL30 6000mhz  |  ASUS ROG STRIX B650E-F GAMING WIFI  | WD Blue SN550 1TB NVMe M.2 SSD, 2TB Samsung 870 EVO, 1TB Samsung 870 EVO, 2TB Seagate Barracuda HDD | Corsair 4000D Airflow  | Corsair RM850x Gold Series
https://linustechtips.com/topic/1589420-psu-replacement/#findComment-16576522
5 hours ago, Mumintroll said:
You can look at this PSU list for help.
https://cultists.network/140/psu-tier-list/
I did I think I'm going to go with the Corsair one
With the power limits exceeded problem is it more of a Mobo problem than a PSU?
https://linustechtips.com/topic/1589420-psu-replacement/#findComment-16576872
