Hi, I have a Berling Navi in my car (don't ask me the excact model right now). It is connected via hotspot with my iPhone.
I can use spotify and listen to music and podcasts, or watch some YouTube while waiting for a friend, even if someone calls me, i can pick it up on the Navi and talk trough there. So everything works fine, but there is a little "problem"
I use google maps alot, to go to customers and pick something up or whatever. So i type in the customers address and it guids me trough it with the voice and drives with me and shows my speed and everything. But on the way home (or when I'm just the neighborhood) I don't need it. Which means I don't need the service anymore, but the google map Navi is like my main window and always open. When I don't put a route in the navi/google maps, it doesn't work anymore. The dot/your car, doesn't update/drive with it on the map. It just stands still. It only updates and shows me where I am when my car stands for like 1 minute or so. Like a traffic light or parking lot or whatever.
My question is, is that normal? I don't think so. Cause it would be cool to see the dot/my car moving around in real time, and not only than when i put a route in it. No idea if this a setting issue from google maps or the Beling Navi itself, I don't know..
Is there a solution to it? Or you now an alternative navigation app (for free) rather than google maps?
Thanks
https://linustechtips.com/topic/1588586-berling-navigation-google-maps-problem/
On 11/12/2024 at 1:10 AM, Tridefender said:
I think this is just how it works, it doesn't update your location in the background... Kinda inconvenient when you need to decide to get off at this station or not.
I tested it with my phone and it drives with me, even tho i don't have a route selected.
It's this one by the way - https://www.car-media.ch/shop/pi/Autoradios/Spezifisch-nach-Automarke/Mitsubishi/LANCER/cartec-px-5-ultra-android-10-autoradio-fuer-mitsubishi-lancer-2008-2016.html?_gl=1*njj80g*_up*MQ..&gclid=EAIaIQobChMI9-W-spTXiQMV_aKDBx0f7hWcEAQYAiABEgK01_D_BwE
Someone know how to change the UI? Or is there a tutorial for this thing? Couldn't find anythi
ng
