Budget (including currency): ~1k-1.5K USD
Country: USA
Games, programs or workloads that it will be used for: everyday computing and FFXIV, Cyberpunk 2077, and Cities Skyline 2 are the main uses
Other details:
Currentley running:
CPU: AMD Ryzen 7 2700X Eight-Core Processor
MOBO: ASUS ROG STRIX B450-F GAMING AM4 AMD B450 SATA 6Gb/s ATX AMD Motherboard
RAM: 2 X G.SKILL TridentZ RGB Series 16GB (2 x 8GB) 288-Pin PC RAM DDR4 3200 (PC4 25600) Desktop Memory Model F4-3200C16D-16GTZR
GPU: GIGABYTE Gaming OC GeForce RTX 3080 10GB GDDR6X PCI Express 4.0 ATX Video Card GV-N3080GAMING OC-10GD
PSU: CORSAIR HXi Series, HX750i, 750 Watt, 80+ Platinum Certified
HDD:
2Tb WD Purple
1TB WD Blue
500GB Seagate
SSD:
Sasmsung SSD 970 EVO plus 2tb
Case:NZXT H9 Flow
honestly the case, GPU and SSD are the only things i wont need to upgrade that is why i am treating this as a new build. but as you can see it has been a while since i have changed out the CPU. Eventually i want to ad an AIO cooler but that is not a priority. I feel like I need ditch the HDD for some SSD's but I do not know much about storage. I will most likely need to get a new windows install since i am technically just running free windows upgrades from Vista so I don't have a key anymore and that the 2tb WD purple is my C drive. If the PSU is strong enough to power everything that would be amazing i would rather not have to swap that out but if that isn't an option i understand. I don't need or even want WI-Fi on the mobo since i hardwired my desktop unless it is unavoidable.
I am also a fan of RGB.
I run two screen 1 27inch samsung curved 1440p at 144hrz and 1 27 inch asus 1080p at 60hz
Thank you all for your help attached is the look of my rig at the moment
https://linustechtips.com/topic/1588345-upgradenew-build-help/
