Ok, so I have a couple questions about this PC I'm building for my friend for his birthday.
Purpose: Light gaming. i.e: this game, http://bout.evolutiongames.net/Game
Specs:
GPU: ATI 4770
CPU: Phenom xII 595 (I think)
RAM: 4GB of HyperX Blu
M/B: Random Biostar motherboard
Case: Cardboard box!
PSU: Buying tommorow probs a 400W
Now, for the questions. So I have a 64 bit OS sitting around. I want to know if 1. 64 bit OS will work with 4GB of RAM 2.Can I use a OEM version of Windows more then once?
Thanks of answers! If you need any more info, just ask!
Someone told Luke and Linus at CES 2017 to "Unban the legend known as Jerakl" and that's about all I've got going for me. (It didn't work)
https://linustechtips.com/topic/158763-low-end-build/
64 bit will work, 32 bit wont.
32 bit maxes out on 4gb of RAM. You just can't use more than 4.
But yes, 64 bit will work.
CPU-AMD FX 8350 @ 4.9Ghz | GPU-Sapphire 7970 OC | Motherboard-AsRock Extreme9 990fx | RAM-8GB Mushkin Blackline Ridgeback
Case-NZXT Switch 810 | Heatsink-NZXT HAVIK | SSD-Samsung 840 250GB | HDD-Seagate Barricuda 1TB; WD Green 2TB
PSU-Seasonic X-Series 850 Watt | Mouse-Razer Naga | Keyboard-Razer Blackwidow | Speakers-Logitech z623
https://linustechtips.com/topic/158763-low-end-build/#findComment-2115680
