ASRock's quality control may be lacking... The threaded inserts for the CPU cooler on a board I have here have issues. I have one that fell out entirely, and one that was pressed in at an angle.
Apparently I'm not using the I'm not using the correct terms to find the information I need. I believe these just get glued in with some sort of adhesive? Can someone point me in the correct direction?
https://linustechtips.com/topic/1587565-cpu-cooler-insert/
What MB CPU combo is this?
Looks more like it should be for a CPU retaining clamp and don't they usually have a backplate?
If you're interested in a product please download and read the manual first.
Don't forget to tag or quote in your reply if you want me to know you've answered or have another question.
https://linustechtips.com/topic/1587565-cpu-cooler-insert/#findComment-16561594
No backplate, it's a thread insert that the cooler screws to. It's a NUC I'm modifying. It's a BOX-155H, Ultra 7 155H that I've been using for OPNsense. It's had a few cores that run really hot though, which got me to looking into it some.
https://linustechtips.com/topic/1587565-cpu-cooler-insert/#findComment-16561604
