Help with Upgrade Path
Solved by venomtail,
Just upgrade to 5800X3D if in stock still, if not settle for 5700X3D.
1440p for eSports games might still be a low enough threshold where CPU performance is important but often pushing into GPU determining territory.
Of course, 9800X3D upgrade is an option but either you're looking now at spending 400eur to a CPU upgrade or all 1200eur for a new platform and I'm not sure you'd see x3 the FPS.
