Building a pc
Go to solution Solved by venomtail,
10 minutes ago, Ibra101 said:
1. CPU: AMD Ryzen 5 7600X
7500F or 7600. Drop the X.
2. GPU: AMD Radeon RX 7600
Meh value. Older 6700XT more convincing as usually same price yet runs better or go 7700XT.
4. RAM: Corsair Vengeance 16GB (2x8GB) DDR5 5200MHz
Slow RAM, 6000MHZ minimum, aim for CL30, the less the better.
Rest is good.
What do you guys think about this build, my goal for it some work running some vms, gaming, and maybe stream later on:
3. Motherboard: ASRock B650M PG Riptide
5. Storage: Kingston NV2 1TB NVMe SSD
6. Power Supply: EVGA 650 BQ, 80+ Bronze, 650W Semi Modular
7. Case: DeepCool Matrexx 50 ATX Mid-Tower
8. CPU Cooler: Vetroo V5 CPU Air Cooler
https://linustechtips.com/topic/1587304-building-a-pc/
Rest is good.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1587304-building-a-pc/#findComment-16559465
Rest is good.
Can you recommend a monitor no more than the price of 300$
https://linustechtips.com/topic/1587304-building-a-pc/#findComment-16559484
Long live 1440p, if curious a review on RTINGS.
https://linustechtips.com/topic/1587304-building-a-pc/#findComment-16559491
27 minutes ago, Ibra101 said:
Anything for 1080p?
ASUS VG279QM1A here. The days for 1080p are numbered, there are entry level 1440p panels that cost as much as this 1080p one. Warmly recommend looking at 1440p, especially as you've mentioned work related needs as well.
https://linustechtips.com/topic/1587304-building-a-pc/#findComment-16559539
