APU Build Help
Go to solution Solved by SAV1OUR,
CPU:  AMD A8-6600K 3.9GHz Quad-Core Processor  ($104.99 @ Newegg)
Motherboard:  Gigabyte GA-F2A55M-HD2 Micro ATX FM2 Motherboard  ($44.98 @ OutletPC)
Storage:  Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($54.43 @ OutletPC)
Case:  Corsair 200R ATX Mid Tower Case  ($54.99 @ Amazon)
Total: $356.37
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-05-28 16:41 EDT-0400)
Total: $356.37
Specs
https://linustechtips.com/topic/158595-apu-build-help/#findComment-2113693
CPU:  AMD A10-6790K 4.0GHz Quad-Core Processor  ($124.98 @ OutletPC)
Motherboard:  Asus A78M-A Micro ATX FM2+ Motherboard  ($55.79 @ Newegg)
Case:  Cooler Master N200 MicroATX Mid Tower Case  ($44.99 @ NCIX US)
Total: $410.67
(Generated by PCPartPicker 2014-05-28 16:50 EDT-0400)
It is FM2+ so you can upgrade to kaveri later if you wanted. You can also add a low-power gpu like a 750ti if you wanted. To save money you can go with the stock cooler but if you are going to game on it, it's gonna sound like a hair dryer and it will be throttling
https://linustechtips.com/topic/158595-apu-build-help/#findComment-2113750
