Budget (including currency): 300 Euro atm
Country: Germany
Games, programs or workloads that it will be used for: League of Legends, Minecraft, Valorant, Satisfactory and maybe some vscode and streaming
CPU: Ryzen 5 2600
GPU: RTX 3060
Motherboard: ROG Strix B450-F gaming
RAM: G.Skill trident z 2x8gb ddr4
Storage: 1x256gb ssd
1x2tb hdd
Edit: added streaming
https://linustechtips.com/topic/1585583-help-how-should-i-upgrade/
Country: Germany
CPU: Ryzen 5 2600
GPU: RTX 3060
1x2tb hdd
https://de.pcpartpicker.com/list/4F7q7R
Update the BIOS on the motherboard
Put a 5700X3D in there.
Get 32GB of RAM.  Maybe buy another 2x8GB DDR4 of the same RAM kit you already have.
Save for a GPU later 🙂
https://de.pcpartpicker.com/list/qcJ4fy
7500f + 32gb 6000c30
id argue that a jump to am5 is a better option considering the resale price of that board cpu and ram should be atleast 90€ which would make this upgrade cost about the same as going for a 5700x3d
7500f will crush the 5700x3d in games that dont leverage the cache that much stuff like minecraft or some fps games but most games where the extra cache is leveraged the 7500f should be able to atleast keep up to the 5700x3d, only times itd lose by a decent margin would be stuff like factorio or satisfactory
you also get the benifit of not having to replace the board or ram upon cpu upgrade once the 7500f isnt cutting it anymore and that 7500f can still be overclocked even further where the 5700x3d probably wont go much past 4.2ghz even if you manage to clock bclk high enough which might be abit of a hassle
also some other stuff like gen4 x16 which is likely to be useful in the next few years and the gen5 m.2 which is useless but hey its just extra overkill
