What could be causing the "metadata staging failed" error 131 (fixed with regedit I think as not event viewer anymore bu this is. Error 100, and 1796 and loads of "warnings". Constant restarts just randomly. Just turned my PC and 7 seconds on desktop and then auto restart. Motherboard? I tested RAM, GPU, and PSU (replaced as was told was failing was from 2016) and thus far nothing has fixed it. Here event viewer if it helps determine. I have a specify URL if you would need that.
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
https://linustechtips.com/topic/1585355-auto-restarts-randomlyplease-help/
25 minutes ago, --SID-- said:
What are the full system specs includes the brand and model of the PSU?
CPU: 7800x3D
MOBO: X670E asrock steel legend
RAM: Corsair Dominator 6000MHZ
GPU: Asus TUF RTX 4080
PSU: Lina LI Edge 1000W (brand new)
All on water.
18 hours ago, --SID-- said:
What's the exact model number and version number of the RAM?
CMT32GX5M2D6000Z36 unsure of version number. I believe it was in the motherboard QVL. Could that cause such an issue. Like not only restarting sometimes I lose internet just randomly as well. New cable might easy fix for that though.
The freezing and audio breaking to motherboard restart is very strange. I've never had so many issues with PCs as of late.
