Hello all you wise people, I wish to be informed if you will share your brainstuffs with me. So i'm preparing for my first video card, if finances work out well I'll be getting a gtx 750Ti soon. I already have a 550 watt power supply, though it isn't name brand but it should be okay. My concern is that the derps that built the PC I use, it's a store bought PC by the way, may not have properly installed the PCIe x16 slot. Though that may sound crazy, once I had an eMachines that had the physical port but it didn't actually do anything. My friend gave a graphics card to try and when I put it in the eMachines nothing happened, even with all the proper drivers and such nonsense. So my simple question is this:
Is there a way to make sure my PCIe port works properly before I go buying a video card?
https://linustechtips.com/topic/158518-preparing-for-first-card/
 You can try testing it with another GPU (I think that it's the only way) And what is the name of your MOBO?
Edit: Fail (it's a prebuilt Pc)
Lord Pantaloons, on 30 Nov 2014 - 7:32 PM, said: If Lawrence leaves his house and travels at a constant 40 MPH. How long will it take Bill from next door to shove a banana up his mom's rectum?
FX-6300Gigabyte R9 270X 4 GB OCWD Blue 1 TBCorsair Carbide 300RArctic Cooling Freezer 7 Pro rev. 2Silverstone Strider Essential 500WAsus M5A97 R2.0Dell P2314HYamaha HTR-5740Mordaunt-Short Avant 309iSuperlux HD-668 BCooler Master CM Storm Quickfire UltimateGigabyte M6900Oneplus One 64 GB
https://linustechtips.com/topic/158518-preparing-for-first-card/#findComment-2112781
Yes, borrow one from a friend first. Doesn't matter if it's a low-end or old graphics card.
Rig: Intel Core i7-2600 / Sapphire R9 280X Dual-X / 2 x 8 GB DDR3-1600 / Seagate Hybrid SSHD 2 TB / FSP500-60APN 500W / 3x 20" 1600x900 LED / 51" Samsung F5000 plasma / Acer K330 LED projector
15.6" Clevo W650SJ: Intel Core i7-4810MQ / Geforce GTX 850M / 1 x 8 GB DDR3-1600 / Hitachi 1 TB 7200 rpm
14" Lenovo Y460: Intel Core i5-520M / Mobility Radeon HD 5650 / 2 x 4 GB DDR3-1333 / Hitachi 500 GB 5400 rpm
https://linustechtips.com/topic/158518-preparing-for-first-card/#findComment-2112784
