So I'm building a new desktop as my secondary machine, while my laptop will be the primary. I'm almost done selecting parts. I'm just stuck at selecting a gpu. I'm stuck between gtx1650 and rx580. Since these are the only cards available in my country for about  $150 bucks, while the more capable rtx3050 6gb variant is priced at $350 in my country. Should I go with the more capable older card without driver support or the newer less capable card with driver support. Also please  note that this is my secondary pc and I can play all the games I want on my laptop as well. I also don't mind upgrading my gpu again in about a year or two.
https://linustechtips.com/topic/1584674-need-help-selecting-a-budget-gpu/
I liked my 1650 when I had it. I liked my RX580 when I had it too. I would take the one with driver updates and upgrade later.
Main Rig:
Ryzen 5800x, ASUS Crosshair Hero VII Wi-Fi, 32gb of Corsair Vengence Pro SL 3600 CL18, Sapphire Pulse 9060xt 16gb, Noctua NH-D15 LTT Edition, Soundblaster AE-7, Beyerdynamic DT 990 Edition 600 Ohm headphones, 1tb ADATA SX8200 NVME SSD, 1tb Intel 665P NVME SSD, 500gb Samsung 850 EVO SATA SSD, 8tb WB Black SATA HDD, 14tb WD Ultrastar HC530, LG SATA Blue Ray Drive, EVGA 1300w G+ PSU, Coolermaster Stryker case, ROG ARGB strips, China ARGB fans.
HTPC:
Ryzen 5800xt, ASUS B550M Prime Plus WiFi II, 32GB of Corsair LPX 3200 CL16, ASUS 5060 8gb LP, Noctua L9-x65 cooler, WD Black SN770 500gb NVME SSD, WD Black SN770 1tb NVME SSD, Crucial MX500 2tb SATA SSD, WD Blue 2tb SATA HDD, Pioneer Blu-Ray burner, Intel AX200 WiFi/Bluetooth, Seasonic 300w TFX PSU, Silverstone ML11 case.
Retro Gamer PC:
VIA C3 1000Mhz, VIA Epia PD-10000 LVDS, 1gb of Kingston DDR, PNY Geforce FX5500 128mb PCI, WD 80GB HDD, Random CD-ROM, Random 250w mini psu, Mini ITX case 🤣
Don't get that scam 3050 6GB for $350, ain't worth even half of that!!!
Really your prices are nuts, can't you get any AMD card ? Any used GPU like a 5700XT ?
budget?
country?
usecases?
other cards available?
580 and 1650 for 150$ is ridicolous as thats nearing used 6700xt pricing where i live (~170-180$ here in indo) and quite abit over a 5700xt (~90$) which still performs much better than a 1650 or rx 580
if the 580 is an 8gb id just pick it assuming its literally the only option as itll be faster than a crappy 1650 whilst having more vram
3 hours ago, pergatorio said:
I'm actually in the process of doing a bit of a budget build myself and I'm aiming for the RX 7600XT. It's capable of 60+fps 1440p, has 16GB VRAM and is in the same ball-park, in terms of price, as the RTX 3050 6GB.
7600xt might even be more overpriced where op lives
also is this a 500$ build or something? you can build a ~500$ rig with a 6700xt and 5600(x) with a mix of used and new (used = 5600(x) 6700xt case and optionally used rm850x or equivalent) and thatd blow away the 7600xt in perf
https://pcpartpicker.com/list/7DQfKX
heres a reference
perf comparisons for 6700xt and 7600xt
32 minutes ago, pergatorio said:
Appreciate the feedback but this is not my thread.
i figured why not since i happened to have an existing pcpp reference cause someone was asking for help on a 500$ build
but damn 7600xt same price as the 3050 where you live? usually theyre closer in price to the 7700xt and 7800xt rather than the 3050
forgot to mention but this thing is just pathetic
and this is the non cut down 8gb version
heres the cut down 6gb version which is even worse in perf
if you can spend that much go buy a used card for an equivalent price even a 6700xt should atleast be available for that price if your prices are that outta whack, i mean its not the 6800xt or 3080 most countries would have at that price but atleast its not a pile of crap that isnt much faster than an old polaris card for over double the price
9 hours ago, EyeInTheTriangle said:
in my country
does your country have a used market worth using? if yes, happy hunting! if no then maybe check intel ark(drivers are mostly fine now, there are like 20 games you have to look out for but other than that games just work now) and price on ark fluctuates on them more than other cards
then maybe consider a amd apu for your cpu and not getting a GPU in the mean while (am4 has some good cheap ones)
