Hello guys
In October I will be starting my Computer Science degree and I decided to finally build my own computer as I currently only use a laptop atm and I hate working on laptops.
I know I don't really need a powerful computer for Computer Science but I do enjoy producing graphics and messing about with C4D and Photoshop. Also I will be gaming on it in my spare time so I thought lets just build a good looking and performing PC.
Here is where I need you guys, I have gathered a list with all the parts for my computer and I just need your thoughts of it and if I may run into compatibility issues e.g. push/pull h100i won't fit in the case with the given mobo etc.
List:
CPU - i7 4770K (will get 4790K if it comes out on 2nd of June)
Mobo - ROG Z97 Hero with Front base bundle
RAM - 16GB Corsair Vengeance Pro (red) 2133
GPU - EVGA 780ti SC ACX
Cooler - H100i with red SP120's push/pull (purely for looks, potentially OC the cpu later on)
Case - Corsair 750D
SSD - Samsung 840 EVO 500GB
HDD - 2TB Seagate Barracuda
PSU - Corsair AX860
Monitor - 24" Asus VG248QE
Keyboard - Corsair K70 Cherry mx red
Mice - Corsair M65
Speakers - Corsair SP2500
Headphones - ROG Asus Orion
Fans - Replace the rear stock 750D with an AF140 red (exhaust), Mount the H100i at the top in push/pull config (exhaust), white corsair 120 led on the bottom next to the psu (intake), keep the stock front fans in 750D as intake.
LED's - NZXT white sleeved LED 200cm
Those are all the parts I have gathered and I think will look pretty good together. What do you guys think of this configuration? Will the h100i in push/pull fit in my 750D or will the Z97 Hero get in the way? what do you think of the white LED's, I was thinking to get red LED's instead.
Please feel free to leave your opinion and any suggestions.
Thank you for reading my thread.
https://linustechtips.com/topic/158430-first-gaming-pc-build/
Looks very good. Don't change anything. I say it, because lots of people, especially fanboys come and suggest worse parts than author has chosen.
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
https://linustechtips.com/topic/158430-first-gaming-pc-build/#findComment-2111693
Nice build, dont worry i wont change anything. If you can afford it we wont change it... hopefully. Welcome to pc gaming bro.
EDIT: I dont know about the push/pull will get in the way but white LED's fo sho'(for sure)
(NOW)War Horse:
CPU: AMD FX-6300 | Motherboard: MSI 970A-G43 | RAM: Corsair Vengeance Dual Channel 8GB 1600Mhz | GPU: MSI R7790 | Case: Dazumba D-Vito 903 | HDD 1 & 2: Seagate 1TB and Seagate 500GB | PSU: Corsair CX600
(WAS)Old Coop:
CPU: Intel C2D E7500 | Motherboard: Gigabyte G31M-ES2L | RAM: V-Gen 4GB Dual Channel | GPU: Galaxy GT210 | Case: Power-Up ??? | HDD: Seagate 500GB | PSU: Power-up 500W
MyAnimeList Profile | Heaven Society | HEIL THE MIGHTY AND POWERFUL LINUS | My Blog 'Unfinished Pieces' | Code of Conduct
https://linustechtips.com/topic/158430-first-gaming-pc-build/#findComment-2111709
I like it! though I have that lighting kit and I am not a fan, maybe look into the alchemy strips that linus is so fond of.
*cough cough*
(NOW)War Horse:
(WAS)Old Coop:
https://linustechtips.com/topic/158430-first-gaming-pc-build/#findComment-2111729
Thanks can't wait to build this! Its good to get other peoples opinions. I will most likely keep it as it is with the potential upgrade of 4790K if it doesn't get delayed.
Thank you bro, maybe we could play together once I build it.
https://linustechtips.com/topic/158430-first-gaming-pc-build/#findComment-2111748
Hoorah, pls dont play anything demanding, my pc is still puny
(NOW)War Horse:
(WAS)Old Coop:
https://linustechtips.com/topic/158430-first-gaming-pc-build/#findComment-2111757
Looks good but I'd like to know what you budget for the pc alone is. Also what it is for the pheripherals alone.
well my budget would be around £2500 which I have currently hit including some other minor items which I didn't mention (mouse pad, hdmi/dvi cables, zip ties etc).
https://linustechtips.com/topic/158430-first-gaming-pc-build/#findComment-2111772
thoses parts seem good, the only thing i would say is maybe not get as big of a ssd
lots of people might tel you to get 2 780 instead of a 780ti, but it will have better upgrade options as you dont have 1 slot used for sli already
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
https://linustechtips.com/topic/158430-first-gaming-pc-build/#findComment-2111815
I wanted to get a large SSD to run most of the software on it and maybe some games that I will be playing frequently. I originally was planning to get the same SSD but 250GB version, I wasn't sure how much space I will have left and my budget allowed me to get the 500GB. Regarding the GPU I may get a second 780ti in the future but as of now I think 780ti will do me more than good and will perform alot better on games that are not SLI optimised.
https://linustechtips.com/topic/158430-first-gaming-pc-build/#findComment-2111877
exactly, with 2 780s you couldnt really add another, good choices
My Rig
Total: $2074.22
https://linustechtips.com/topic/158430-first-gaming-pc-build/#findComment-2111882
Ok then have a look at this
PCPartPicker part list: http://uk.pcpartpicker.com/p/KkJKcf
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor  (£233.99 @ Aria PC)
CPU Cooler: be quiet! Dark Rock Pro 3 93.3 CFM Fluid Dynamic Bearing CPU Cooler  (£64.38 @ Aria PC)
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard  (£164.36 @ Scan.co.uk)
Memory: Patriot Viper 3 16GB (2 x 8GB) DDR3-1600 Memory  (£102.44 @ Amazon UK)
Storage: Samsung 840 EVO 500GB 2.5" Solid State Drive  (£190.60 @ Aria PC)
Storage: Western Digital Red 4TB 3.5" 5900RPM Internal Hard Drive  (£113.99 @ Aria PC)
Video Card: Asus GeForce GTX 780 Ti 3GB DirectCU II Video Card  (£529.99 @ Novatech)
Case: NZXT H440 (Red/Black) ATX Mid Tower Case  (£91.73 @ Scan.co.uk)
Power Supply: Corsair RM 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (£83.93 @ Aria PC)
Monitor: Asus PB278Q 27.0" Monitor  (£447.92 @ Scan.co.uk)
Other: Corsair K70 in black with a red backligth and cherry mx browns. (The best cherry keys IMO) (£107.90)
Other: Corsair Vengance 2100 wireless gaming headset (£99.10)
Other: Logictech G 502 ( I love mine)  (£60.19)
Other: Steel Series QCK mousemat (£7.01)
Other: Corsair SP 2500 (£154.86)
Other: 3x Be quiet! Silent Wings 2 (£49.85)
Total: £2502.24
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-05-28 15:25 BST+0100)
If you wonder why used certain parts just qoute me and ask me. I have personal experience with almost all the products I suggested.
https://linustechtips.com/topic/158430-first-gaming-pc-build/#findComment-2111885
