Best CPU for coding?
2 hours ago, Blasty Blosty said:Would an Intel-based system or a Ryzen-based system be better for a developer? I will be building a new pc for my job (paid for by work - no worry about budget), and I am wondering what the best CPU would be for performance. My coworker went with a 14900K for his, but with the recent release of the 9950x, is this a better choice? Or something like a 7950X3D?
I am using Visual Studio, currently developing in C# Windows Forms, ASP.NET Core web development, and looking to move towards Android development (this will be using an emulator).
AMD has recently almost always had higher "brrrt" of performance,
mainly because Intel was creeping up with power consumption and didn't bother as much with efficiency,
then sort of fixed it, but they started using E-cores,
so mostly, at least recently, Ryzen vs Intel gives Ryzen an easy win each time the core count is the same, as we can see in new 9000 series,..
