The 16pin adapter is only for Nvidia 4000 series with 12VHPWR
For all other cards use the 8pin or 6+2 directly
https://linustechtips.com/topic/1584197-gpu-power-requirement/#findComment-16534807
Yes, you can use it.
The rtx 4080 uses the 16 pin on the gpu side (top right picture).
As I read it the left hand plugs on the pictures goes into the PSU. If it has the 6+2 pin PCIe plug on the GPU end you can use it. it doesn't matter what the plug on the PSU side looks like
If you want me to answer, please use the quote function or tag me. I dont get notified unless you do
https://linustechtips.com/topic/1584197-gpu-power-requirement/#findComment-16534811
so i can safely use a single 16 pin from psu to 2 x 6+2 pin gpu pin bottom pic highlighted wire for my rx 7800xt, i want to reduce the wire clutter as this wire is sleeved and looks neat
https://linustechtips.com/topic/1584197-gpu-power-requirement/#findComment-16534819
Yes, you can
https://linustechtips.com/topic/1584197-gpu-power-requirement/#findComment-16534828
17 hours ago, Tegneren said:
Yes, you can
thanks alot u r a life saver,as it is an old matx case i was a bit tight for space and this will make it a lot better, i have one more question, the mother board has a 8 pin and 4 pin eps connector can i getaway with just connecting the 8 pin ?
https://linustechtips.com/topic/1584197-gpu-power-requirement/#findComment-16535552
Yes. The extra 4-pin is basically there only for extreme overclocking of high-end cpu's
https://linustechtips.com/topic/1584197-gpu-power-requirement/#findComment-16535643
