Budget (including currency): Around 1600 USD
Country: United States
Games, programs or workloads that it will be used for: Lots of modded games, (Risk of Rain 2, Minecraft, Terraria, Baldur's Gate 3) want to be able to play more intensive games without much struggle but I don't really plan on getting super big graphics on like, Forza.
https://pcpartpicker.com/list/mfttcH
I already have any peripherals I need, generally playing at 1440p would be nice but I don't super care. This is my first build as mentioned so any advice on parts and such would be appreciated!
https://linustechtips.com/topic/1584130-working-on-my-first-built-pc/
PCPartPicker Part List
CPU: AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor ($249.00 @ Amazon)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler ($35.90 @ Amazon)
Motherboard: Gigabyte B650 EAGLE AX ATX AM5 Motherboard ($159.99 @ Amazon)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($85.99 @ Amazon)
Storage: Western Digital WD_Black SN850X 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($149.90 @ Amazon)
Video Card: ASRock Challenger OC Radeon RX 7900 GRE 16 GB Video Card ($529.99 @ Newegg)
Case: Phanteks XT PRO ULTRA ATX Mid Tower Case ($85.98 @ Newegg)
Power Supply: be quiet! Pure Power 12 M 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($114.90 @ Amazon)
Operating System: Microsoft Windows 10 Pro OEM - DVD 64-bit
Total: $1411.65
Generated by PCPartPicker 2024-09-30 14:35 EDT-0400
Replace cooler with the spirit EVO, noctua is good but overpriced ngl.
Also change that ram to black, aesthetics police might report you.
Case is on a more expensive side, but I think it's fine.
With the leftover money from the changes, you should have enough for a 7900GRE. Good gpu.
Lot of bad value choices
Can get way better for that budget :
EDIT : even better now, didn't notice the scalped 7800X3D US prices !!
CPU: AMD Ryzen 7 9700X 3.8 GHz 8-Core Processor  ($330.00 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($34.90 @ Amazon)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($99.99 @ Amazon)
Storage: Western Digital Blue SN580 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($115.32 @ Amazon)
Video Card: XFX Speedster MERC 310 Radeon RX 7900 XT 20 GB Video Card  ($679.99 @ Amazon)
Case: Lian Li LANCOOL 216 RGB ATX Mid Tower Case  ($99.99 @ Adorama)
Total: $1635.08
Generated by PCPartPicker 2024-09-30 15:01 EDT-0400
The ram comes in black, but its only white on PCPartPicker so it looks odd. Appreciate the advice though! Anything about the power supply? So far its the item I'm least sure about.
I see. No seasonic's good.
Give me a little bit I'll see what i can min max while using the case you picked.
Here's what I came up with:
PCPartPicker Part List: https://pcpartpicker.com/list/fZFvz6
CPU: AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor  ($233.23 @ Amazon)
CPU Cooler: Thermalright Phantom Spirit EVO 69 CFM CPU Cooler  ($49.90 @ Amazon)
Memory: TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($102.99 @ Amazon)
Storage: Acer Predator GM7000 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($136.99 @ Amazon)
Video Card: XFX RX-79GMERCB9 Radeon RX 7900 GRE 16 GB Video Card  ($549.99 @ Amazon)
Case: Fractal Design Torrent RGB ATX Mid Tower Case  ($179.99 @ Amazon)
Power Supply: Corsair RM850x (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($114.99 @ Amazon)
Total: $1528.07
Generated by PCPartPicker 2024-09-30 15:43 EDT-0400
7700x is good, 7800x3d is preferable, but the price is really high right now, the 7700X will still handle your pc no problems.
 changed the noctua to a spirit evo, as i said, noctua's a bit overpriced.
Motherboard's good.
Don't forget the memory in black.
Probably one of the better SSD's you can get. It's fast, it's at a great price and has a dram cache. You could get a gen5 ssd but honestly, dont bother.
Get any 7900GRE you can, it's a killer gpu for 1440p. Just make sure you get a 3 fan for best cooling and review the said GPU. Never know what could be wrong with it until others or you have tried it.
Kept the case as is, since that's your choice.
I went with the 850x, gives you a bit more headroom for upgrades, and it's an overall good PSU in my personal opinion.
Black memory modules  https://pcpartpicker.com/product/2JLFf7/teamgroup-t-force-delta-rgb-32-gb-2-x-16-gb-ddr5-6000-cl30-memory-ff3d532g6000hc30dc01
The Seasonic Focus model selected is very good. However it is an older model and is not ATX 3.x compliant. For just a few $ more one can get an equally good ATX 3.x compliant model, just not one that is Seasonic branded.
Alright! Going through all the suggestions I've ended with this list. It's more expensive- but only because its going towards a nicer GPU which is great. I've checked everything and it seems like it all fits and works together now. I very much appreciate the help! Any thoughts on this now?
PCPartPicker Part List: https://pcpartpicker.com/list/NXzQ89
Total: $1506.40
Generated by PCPartPicker 2024-09-30 17:19 EDT-0400
Total: $1506.40
The CPU cooler outer fan extends over the memory area. Which means that the memory RGB lighting will be at best partially obscured.
The memory modules are ~46 mm tall. Normal clearance under the CPU cooler is ~42 mm. While the outer fan can be adjusted upwards (presuming case clearance) using low profile memory modules makes more sense.
The 2021 RMx models are not ATX 3.x compliant.
