When I first built my computer I read online that the haswell processor could not handle the voltage needed for my Kingston beast ram.
What would happen of I was to increase the voltage news for the ram in the bios?
Main Rig - Case: Fractal Design Pop Air XL Motherboard: Asus TUF B650 Plus WIFI CPU: AMD Ryzen 5 7600 RAM: Corsair Nautilus 240 RAM: Corsair Vengeance 16GB 3000MHz32GB Corsair Vengeance DDR5 6000MHz  SSD: 1 TB 1TB Samsung 990 Pro NVMe
HDD: 2TB WD Blue  GPU: Asus RTX4070 Dual Evo PSU: Corsair RM850X
Corsair 200R Front Bezel Mod
https://linustechtips.com/topic/158405-cpu-and-memory-voltage/
you are fine unless you are running more than 1.65v for rams.
https://linustechtips.com/topic/158405-cpu-and-memory-voltage/#findComment-2111442
im running hyper xbeast on haswell
xmp profile suggest 1.65V for 2400mhz profile.
i actually need 1.71V for 2400mhz stability. ( this is true for many other memory vendors as well)
http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
https://linustechtips.com/topic/158405-cpu-and-memory-voltage/#findComment-2112209
Would it be safe for me to increase it then?
https://linustechtips.com/topic/158405-cpu-and-memory-voltage/#findComment-2112364
