Hullo,
I've tried installing linux mint 16 onto my old laptop to dual boot with windows 7. Obviously, I set it to "install alongside windows 7"
I created a new partition through Mint to install Mint on, and set the partition position to be "at the end" (don't know if that's any significance), and the mount point to be /.
Now that it's "installed" it isn't letting me boot into windows OR Mint, it just sits there with the blinking console underscore thing and makes sounds when I type anything.
So...I went back to the Mint install usb drive to check what it's done to my drives. It's showing that my previous partition is now a "Linux Mint 16 Petra (16)" system, and so is the supposed Mint partition...
Anyone know what might have happened and/or how I can fix it?
Help appreciated.
Home is where the heart my desktop is.
https://linustechtips.com/topic/158362-help-with-linux-mint/
This sounds VERY weird. Sometimes with my Ubuntu install (which ment is based on) will boot up to a weird terminal. Have you tried the startx command? This should start the display server and let you start up applications or packages in Mint.
Edit: Also when I stuffed up in Ubuntu I would just reinstall the whole OS. Even small things like not knowing to uninstall stuff.
Edited by joshuamurphy
Cpu: Intel i5- 4570 | Ram: Crucial DDR3 8GB | Video Card: Evega GTX 660 Ti 2GB Super Clocked
Monitor: Philips 24" | Keyboard: CM Storm Quickfire TK | Mouse: Logitech G700s |
Steam
https://linustechtips.com/topic/158362-help-with-linux-mint/#findComment-2110766
So...coming back with the bootable usb, I went to the disk management/viewers and found that mint has quite kindly (sarcasm) installed mint onto the main partition and is showing that I have 379 of 410 GB free...
SO...I assume that means it has kindly deleted my windows 7 files for me?
Edit: Hmmm...I suppose I should have put this in the troubleshooting topic shouldn't I
https://linustechtips.com/topic/158362-help-with-linux-mint/#findComment-2110796
