PCPartPicker Part List
CPU: *AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($114.83 @ B&H)
Motherboard: *ASRock B550M Pro4 Micro ATX AM4 Motherboard  ($89.99 @ Newegg)
Memory: *Silicon Power GAMING 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($28.97 @ Amazon)
Storage: *Patriot P210 1 TB 2.5" Solid State Drive  ($48.99 @ Newegg Sellers)
Video Card: *Gigabyte EAGLE Radeon RX 6600 8 GB Video Card  ($179.99 @ Newegg)
Case: *Fractal Design Pop Air ATX Mid Tower Case  ($58.96 @ Newegg)
Power Supply: MSI MAG A650BN 650 W 80+ Bronze Certified ATX Power Supply  ($67.11 @ Amazon)
Total: $588.84
Generated by PCPartPicker 2024-09-17 19:53 EDT-0400
https://linustechtips.com/topic/1582952-pc-build-help/#findComment-16523981
CPU: *Intel Core i5-12400F 2.5 GHz 6-Core Processor  ($111.99 @ Amazon)
Motherboard: *ASRock B660M Pro RS Micro ATX LGA1700 Motherboard  ($94.99 @ Amazon)
Total: $591.00
Generated by PCPartPicker 2024-09-17 19:54 EDT-0400
https://linustechtips.com/topic/1582952-pc-build-help/#findComment-16523982
$450 is a pretty tight budget for even a meh used system, unless you go ultra budget new parts are off the table.
What game/games are they trying to play?
Is $450 the total budget? Including tax and everything or is there some wiggle room? Only curious because PCpartpicker pricing is not the total price, it does not include tax.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1582952-pc-build-help/#findComment-16523984
Just now, omsoc said:
They are trying to run some low demanding vr games and some flatscreen games. They also have 488 dollars but i thought i might add a little wiggle room. Also i have a power supply so maybe cut that out of the budget.
Can you be more specific with which games? Also what resolution they are trying to play at? With a maximum budget of $488 it may be best for you to look at used options on Facebook Marketplace or Ebay. If you find something that fits your budget and you want to know if it is a good deal you can post back here and we can take a look. $488 is just really low for a brand new custom gaming PC.
An option a lot of people do with such a low budget over just buying a console is purchasing an HP Prodesk, like a 10th Gen i5, 16GB Ram, 512GB Nvme off of ebay for around $200 to $250 then put a Radeon low profile GPU in it. I could link you some options if that is something you'd be interested in.
https://linustechtips.com/topic/1582952-pc-build-help/#findComment-16523990
They are trying to run gta 5 and blade and socery both at 1080p. The parts also dont have to be completely new and i think having am4 might be decent for upgradeability.
https://linustechtips.com/topic/1582952-pc-build-help/#findComment-16523998
