heating issue
Go to solution Solved by DoctorNick,
5 hours ago, Kamranbites said:
yaah they are tight no gap between heatsink and processor
you might wanna try again anyways
4 minutes ago, Kamranbites said:
i have lenovo x280
temps go up to 90c when opening apps or seeing videos on youtube
when idle temps are 55c
attaching pics of temp details
Its a fairly old laptop. Change the thermal paste. Keep in mind that these run hot either way. But 55c idle is a little high
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1582355-heating-issue/#findComment-16517943
Like 4 months back changed it
Should I change it again
I think 4 months is not too long
https://linustechtips.com/topic/1582355-heating-issue/#findComment-16518035
Nope but are you sure you did a good job and tightened the screws enough?
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1582355-heating-issue/#findComment-16518100
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1582355-heating-issue/#findComment-16518736
3 hours ago, Kamranbites said:
Will try it once more
So what if same thing continues?
You have to find out what is normal temperature before you can come to any logical conclusions. ThinkPads do run hot.
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1582355-heating-issue/#findComment-16518957
Looked online
Idle temp should be between 35-45c
Games or intensive application.55-65
But my case idle is high,
 if running games or intensive application it is near 80-90
https://linustechtips.com/topic/1582355-heating-issue/#findComment-16518970
Looked online
That seem unrealistic from my experience. Also what games can you really play on a x280? My T14 gen 1 for example runs up to 95C while running fairly light loads. Its an office PC.
This thread shows the same thing:
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1582355-heating-issue/#findComment-16519091
So well just replace thermal paste and tight up the heatsink
That's the only thing we can do right?
Apart for that tired to reinstall windows 11
Still same temps
https://linustechtips.com/topic/1582355-heating-issue/#findComment-16520067
