Does this case have vertical GPU mount?
Solved by Poinkachu,
51 minutes ago, IkeaGnome said:I forget which exact mount I suggested to @RevGAM, but I think they ended up liking it. They might still have the link.
Noting that that case only has 6 brackets.
I think the only two suitable for it are :
CoolerMaster V3
or
Any that doesn't mount on PCIE brackets
(Might be others that mount on PCIE brackets that only needs less than 7, my knowledge doesn't encompass the whole universe afterall
edit: Found your answer
