RAM Speed Documentation Confusing
Solved by Eigenvektor,
6000 MT/s CL30 is the generally recommended sweet spot. Best in terms of price to performance that still allows memory and IF to run at 1:1 speed. Going higher than this is less likely to work and generally doesn't actually give you a performance boost.
derekchan ·
Posted in New Builds and Planning4 -
1
5
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting6 -
DavidPatrascu ·
Posted in General Discussion9
play_circle_filled
Latest From ShortCircuit:
