My home wifi network isn't loading specific websites like quora etc. when I try the same instead with mobile data it just loads with no problem. I'm aware that there are certain things I can change in the router settings page, but due to my lack of awareness about dealing with network or anything to do with it I'm seeking any sort of advice to fix this issue
https://linustechtips.com/topic/1580756-wifi-not-loading-specific-websites/
Do you have any sort of network blocker etc. like Pihole?
Or are you just using a standard router, and if so, which router?
General nerd and programmer. Chronically online.
Current build: AMD Ryzen 5 8600G | AMD Radeon 760M iGPU | Intel Arc B580 dGPU (Acer Nitro OC) | ASUS PRIME B650M-R Corsair Vengeance RGB DDR5-6000 CL30 2x16GB | Kingston NV3 500GB M.2 SSD | Crucial P3 Plus 500GB M.2 SSD | Noctua U12S redux | Noctua NAFK1 Dual Fan Kit | Gigabyte UD-GM PG5 750W 80+ Gold PSU CiT Vento Thermalright 8x ARGB + PWM controller
  • 2 weeks later...
