hey, so i want to get into pc gaming and im having trouble with picking monitors. i'm looking at, to start with dual monitors to begin with and then down the road to a 3rd, with my budget i can afford a combined $300 (Canadian) for two! with some research, i've found that i don't want anything over 5ms  and 1080p screen resolution, if you guys could help it would be greatly appreciated!
https://linustechtips.com/topic/158072-monitors-for-beginners/
https://linustechtips.com/topic/158072-monitors-for-beginners/#findComment-2106811
There are, quite literally, hundreds of options out there. Why not just go on Newegg, go into the Monitors subcategory, and use Filters for price & such?
Here are the specs you should look for:
1) IPS Panel [Most would agree on this, for picture quality. For competitive or professional gaming, without a care for color reproduction & accuracy, you can go with a good 120Hz+ TN panel]
2) 5ms-8ms or less Response Time - but keep in mind, do research when you've eliminated all but a handful, because that spec is not accurate, per professional testing
3) Low Input Lag - for gaming, this is important and is most commonly associated with 'ghosting'.
4) Some brands I personally recommend for IPS panels: ASUS, Dell, LG & Samsung (PLS, mostly). Those are the top 4 for IPS, again per my opinion. Some other good models are from: HP, AOC and Acer.
5) For 1080p, I would go with up to a ~24", especially with a triple-monitor setup. Not only will a 1080p resolution look better on a 23"-24" over say, a 27" - but also depending on the distance you are sitting, you won't have to break your neck to enjoy the surround experience.
« Current PC ~ Phantom Beast »
https://linustechtips.com/topic/158072-monitors-for-beginners/#findComment-2106816
