PC Bluescreen help
1 hour ago, bomberblyat said:Well i installed new ssd and just now i saw a same warning whea logger basically any ideas? no blue screens so far atleast
A corrected hardware error has occurred.
Component: PCI Express Root Port
Error Source: Advanced Error Reporting (PCI Express)Primary Bus:Device:Function: 0x0:0x1C:0x0
Secondary Bus:Device:Function: 0x0:0x0:0x0
Primary Device Name:PCI\VEN_8086&DEV_7AB8&SUBSYS_376917AA&REV_11
Secondary Device Name:I UPDATED REALTEK DRIVER, IT SEEMS TO BE ACTUALLY DIFFERENT DEVICE ERROR NOW IDK IF THAT COULD FIX IT
That it's now blaming something else is weird. And it's not like networking and storage have anything in common.
It was unclear from your post if you updated the Realtek driver after seeing this, but if it fixes it then great. If it doesn't I don't really know what to suspect, maybe the motherboard. These PCIe pins go to the CPU, but you would need to have a lots of pins affected for it affect multiple different devices like this. If the shop is taking this seriously, and you are under warranty, I would just send it back saying it's still having issues.
