PSU cable intercompatibility
Go to solution Solved by DoctorNick,
1 hour ago, lazykid14 said:
Hi does anyone here know if I can use my PSU pcie cable
-from a FSP Hydro G pro 750w (80plus gold)
-to a FSP Hydro PTM Pro 750w (80plus platinum)
Thanks
I found this. This very likelý as they're are the same brand. https://www.ensourced.net/modular-cable-compatibility-chart/
I'm assuming your Hydro G Pro died and you bought the PTM Pro as a replacement?
I haven't been able to find any official information. Even CableMod doesn't have off-the-rack kits for FSP power supplies, they're only available through the configurator.
Can FSP support tell you?
Do you have a multimeter? Both power supplies should come with cables, so you can always beep them out with the meter in continuity mode to make sure they have the same pinout. It's tedious, but if support can't help you it may be the only way.
Thanks
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
it's more like a friend of mine who has a PTM Pro threw away the box together with the extra cables. And just today he bought a new GPU that needs 3 8pin connectors. the old gpu only needed 1 8pin so.
as for the hydro G pro, I have that right now and have the extra cable. I'm wondering if I can just give it to him since ordering a new cable will be next to impossible in our country. not to mention, very expensive.
I have reached out to FSP support too but I'm not too keen on their "timely" response.
I also asked FSP support if i can use the hydro g cables for my old FSP Aurum Xilenser lol. It's still working and I might use it with the old gpu I got from my friend.
Edited by lazykid14
added another question
Yes FSP makes there own PSU's and is OEM for other venders. The chart above show that the two you've mentioned is compatible.
Gaming PC:
Linux PC:
Thanks for the info and the help. We got that sorted out earlier.
Only thing now is if I can do the same with my old fsp aurum xilenser lol
Золотая тишина. Обзор блока питания FSP Aurum Xilenser 500W /  Overclockers.ua
As you can see the plug doesn't fit 🙂
Gaming PC:
Linux PC:
Ah dang it. Looks like I have to buy a new psu 😔
I really liked the fanless feature of it too so I was hoping to make use of it. I guess a cheap 80plus bronze will do in the meantime
Thanks for pointing it out. 🙏
