Budget (including currency): 2400 eur
Country: Czech Republic
Games, programs or workloads that it will be used for: Split between games and WebBrowsing and Programming. I lie to myself that I am a gamer, but I mostly play online games with friends like WoW, DotA2 and SC2. Occasionally I like to try some AAA titles, I've played Witcher3, Assasin'sCreed BlackFlag and most recently Baldur's Gate 3.
Other details There are no PC shops near me, so I will order everything through big local shop that delivers to me, alza.cz, which is why some choices might be limited.
From reading through different posts here, some YT benchmarks and etc, I've gotten the impression that the budget of 2400 eur is most likely extremely overkill for my needs, as these are mostly light weight games. However, I have this budget currently, and I don't know if or when will I be able to spend on my PC again, so I'd like to get something that might as well last some time.
I have a 32" slightly curved monitor, so it's a little higher resolution than standard 24".
I would also like to buy all parts new, I had bad experience with used, and if everything is bought through alza it will assemble the PC for me, and add 3 years warranty on top of it.
Thank you for taking the time to help!
https://linustechtips.com/topic/1580164-general-gaming-pc-build/
What's the programming workload? Professional, hobby? Light work, heavy?
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
It's mostly hobby stuff, I have a dedicated work laptop. So something like PyCharm, DockerHub, some web dev in Chrome etc. Since I have a big monitor, I often have it split into 2/3 sections, each with its own web browsers and a few tabs.
This should be a good balance between price, gaming performance and programming performance
PCPartPicker Part List
CPU: AMD Ryzen 7 7700 3.6 GHz 8-Core Processor  (7790.00Kč @ Alza)
CPU Cooler: ARCTIC Liquid Freezer III A-RGB 48.82 CFM Liquid CPU Cooler  (1899.00Kč @ Alza)
Motherboard: Gigabyte B650 EAGLE AX ATX AM5 Motherboard  (3869.00Kč @ Alza)
Memory: Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (2919.00Kč @ Alza)
Storage: Western Digital Blue SN580 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (2999.00Kč @ Alza)
Video Card: Sapphire PULSE Radeon RX 7800 XT 16 GB Video Card  (13190.00Kč @ Alza)
Case: Montech AIR 903 BASE ATX Mid Tower Case  (1869.00Kč @ Alza)
Power Supply: Gigabyte UD750GM 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (2029.00Kč @ Alza)
Total: 36564.00Kč
Generated by PCPartPicker 2024-08-21 09:49 CEST+0200
Also, for one, you dont, need to label yourself into or not into a bracket
and secondly;
You play games, by definition, youre a gamer, dont need to lie to yourself 😋
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
For light hobby stuff and somewhat light games, I don't think you need to go bleeding edge, just get the average, fat trimmed parts that are great value for money. We can still play around with this build just as adding more fans to case, getting a more cohesive look. Extra 2TB SSD for all the games you could need. Plenty of budget left over:
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (4990.00Kč @ Alza)
CPU Cooler: ARCTIC Freezer 36 CPU Cooler  (689.00Kč @ Alza)
Storage: Crucial P3 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (1599.00Kč @ Alza)
Storage: Crucial P3 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (2990.00Kč @ Alza)
Video Card: XFX Speedster QICK 319 Core Radeon RX 7800 XT 16 GB Video Card  (13499.00Kč @ Alza)
Case: NZXT H5 Flow ATX Mid Tower Case  (2029.00Kč @ Alza)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (2899.00Kč @ Alza)
Total: 35483.00Kč
Generated by PCPartPicker 2024-08-21 09:45 CEST+0200
CPU: AMD Ryzen 9 7900 3.6 GHz 12-Core Processor  (9090.00Kč @ Alza)
Total: 37864.00Kč
Generated by PCPartPicker 2024-08-21 09:41 CEST+0200
and secondly;
For light hobby stuff and somewhat light games, I don't think you need to go bleeding edge, just get the average, fat trimmed parts that are great value for money. We can still play around with this build just as adding more fans to case, getting a more cohesive look. Plenty of budget left over:
Total: 35483.00Kč
Wow! Both of you guys came up with very similar builds, and it's like 1/2 of my budget. It really doesn't make sense to invest more in it? Will it be diminishing returns?
On the other hand, I'd rather spend a few 100 euros more today, than have to think about buying a new component in 1-2 years.
So maybe I'd invest just a little more in the CPU and GPU, and the other stuff can be more on the lower-mid-range spectrum?
I was initially looking at the 4070 Ti Super and wasn't sure between the 7950x3d or 7800x3d. However, from your comments it seems to be unnecessary?
Moreso, the games youre playing arent super intensive, so the extra 100 quid will get you an equivalent amount more performance, but getting something like 500 vs 650 fps in DOTA2 just seems unnecessary/redundant if you get me
Few changes based on taking some of @venomtail's suggestion too
CPU Cooler: ARCTIC Freezer 36 CPU Cooler  (639.00Kč @ Alza)
Total: 36483.00Kč
Generated by PCPartPicker 2024-08-21 10:04 CEST+0200
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
The 120mm fan goes inside the back of this case for a exhaust fan.
CPU: *AMD Ryzen 7 7700 3.6 GHz 8-Core Processor  (7790.00Kč @ Alza)
CPU Cooler: *be quiet! Dark Rock 4 CPU Cooler  (1919.00Kč @ Alza)
Motherboard: *MSI PRO B650-S WIFI ATX AM5 Motherboard  (3799.00Kč @ Alza)
Memory: *Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (2919.00Kč @ Alza)
Storage: *Western Digital Blue SN580 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (2999.00Kč @ Alza)
Video Card: *Gigabyte WINDFORCE OC GeForce RTX 4070 Ti SUPER 16 GB Video Card  (22490.00Kč @ Alza)
Case: *Fractal Design Focus 2 ATX Mid Tower Case  (1859.00Kč @ Alza)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (2899.00Kč @ Alza)
Case Fan: *ARCTIC P12 PWM PST 56.3 CFM 120 mm Fan  (149.00Kč @ Alza)
Total: 46823.00Kč
Generated by PCPartPicker 2024-08-21 09:55 CEST+0200
A better look at that case.
https://www.fractal-design.com/products/cases/focus/focus-2/black-solid/
With my configuration, I've sort of already invested the extra 100 into better future upgradability parts.
An ATX motherboard if you ever need to expand to thicker cards or add new parts.
PSU with new 12VHPWR connector for future cards.
B650 motherboard to hopefully have better chances of new CPU support years down the line.
Case that should be easy to build in, have good airflow and look good years later.
Yes, 7800X3D is the best gaming CPU but in such light titles (arguably simply not heavy titles) there's less importance on the CPU. If you were a dedicated eSports player or simulations, or needed the fastest then sure, that CPU is a great choice. The 4070TI is also a good card but simply less value for money than what AMD offers, and the extra features they offer (Basically only better ray tracing performance) isn't something that outweighs the cost savings for me.
CPU: *Intel Core i7-13700F 2.1 GHz 16-Core Processor  (10490.00Kč @ Alza)
CPU Cooler: *be quiet! Dark Rock Elite CPU Cooler  (2799.00Kč @ Alza)
Motherboard: *MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard  (3689.00Kč @ Alza)
Total: 50293.00Kč
Generated by PCPartPicker 2024-08-21 10:37 CEST+0200
Thank you all for the suggestions. I am convinced that it doesn't make a lot of sense to spend the whole budget, especially for my use case.
Despite that, I still want to beef up the CPU and GPU somewhat, and landed on these two. I like the idea of having a 12 Core CPU for multi-tasking etc, but I am a little worried that it has it's own stock cpu cooler? Is that really OK? Or should I get a dedicated cooler for it?
I think the MoBo wasn't compatible, so I picked this slightly more expensive one with really good reviews and options to upgrade, as the budget is not tight.
Also, is the case big enough? I keep reading about airflow being important, and how some cases are like an oven, while others are OK.
Does this make sense? Or am I better off getting the 7900X or 7950X with a dedicated CPU cooler?
Thanks again!
PCPartPicker Part List: https://cz.pcpartpicker.com/list/Xz9zqR
Motherboard: Asus ROG STRIX B650-A GAMING WIFI ATX AM5 Motherboard  (6249.00Kč @ Alza)
Video Card: XFX Speedster SWFT 319 Radeon RX 6800 16 GB Video Card  (9999.00Kč @ Alza)
Case: Fractal Design Focus 2 ATX Mid Tower Case  (1859.00Kč @ Alza)
Total: 36014.00Kč
