I am buying a new gaming PC and wanted to double check if all my parts will work together and fit and etc here are the parts I would be getting, Intel Core i7 4770, CoolerMaster Hyper 212X, ASUS MAXIMUS VII HERO, Palit GeForce GTX 760 JetStream, CoolerMaster CM Storm Trooper ATX, BenQ RL2455HM, Seagate ST1000DX001[1TB], G.SKILL RipjawsX F3-12800CL7D-8GBXM, Corsair HX750, Windows 7 Home Premium 64 bit. I hope you can tell me this since I don't know about computers too well. Thanks.
Price: Max 1600$
 Note: I'm probably not going to overclock.
https://linustechtips.com/topic/157951-my-pc-build-help/
Yeah those will work but I'm going to assume this is for gaming correct? You could switch some stuff around and get better gaming performance.
My Rig "Corsair air 540, MSI Z87-G45, i5 4670k, EVGA ACX 780, Gskill sniper 2x8gb 1866 memory, Corsair CX500m modular 80+ bronze, corsiar h100i, toshiba 1.5tb HDD." / Peripherals "Acer H226HQLbid Black 21.5" (Main monitor), Acer S200HLAbd Black 20" (auxiliary), Razer blackwidow ultimate 2013, razer naga 2013, razer goliathus 444x355 speed edition, Sennheiser HD8 DJs"
https://linustechtips.com/topic/157951-my-pc-build-help/#findComment-2105294
1. why a non ocing cpu and a ocing motherboard?
2. uses?
3. budget and location?
use the quote button if you want my help
Specs
https://linustechtips.com/topic/157951-my-pc-build-help/#findComment-2105298
Where should I start....
What is your budget? Location?
If this is going to be used only for games, replace the i7 with an i5 4670K and overclock it a bit, or if you REALLY want or need an i7, get the 4770K and overclock that. Motherboard - you can easily pay 100 $ dollars less for one that will be just as good. You can use that money on a better GPU instead. Also, your PSU is WAY too big, 500-550W should be enough on a quality unit. Also, you should get an SSD, since you are getting such a high-end rig.
Do you already have the OS or are you buying it? If you are getting a new OS, get Windows 8.1, 7 has no benefits compared to 8.1.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/157951-my-pc-build-help/#findComment-2105313
For MOBO get. It is a solid no frills gaming motherboard. I have one it's super solid and pretty good looking.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130771
For CPU get
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116899&cm_re=i5_4670k-_-19-116-899-_-Product
It is pretty much the same performance it's cheaper and is a K edition meaning you can overclock it in the future for improved performance.
and replace your GPU with
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127741&cm_re=GTX_770-_-14-127-741-_-Product
The GTX 770 is a very solid card and with the money you save on your MOBO and CPU it will still cost about the same : D
https://linustechtips.com/topic/157951-my-pc-build-help/#findComment-2105317
CPU:  Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($229.98 @ OutletPC)
Motherboard:  MSI Z87-G45 Gaming ATX LGA1150 Motherboard  ($133.98 @ SuperBiiz)
Storage:  Samsung 840 EVO 250GB 2.5" Solid State Disk  ($139.99 @ Amazon)
Storage:  Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($83.97 @ OutletPC)
Video Card:  Asus GeForce GTX 780 3GB DirectCU II Video Card  ($488.79 @ Amazon)
Operating System:  Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Monitor:  BenQ RL2455HM 60Hz 24.0" Monitor  ($179.99 @ Amazon)
Total: $1541.60
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-05-27 11:01 EDT-0400)
https://linustechtips.com/topic/157951-my-pc-build-help/#findComment-2105373
Total: $1541.60
Why note a sshd instead of getting both ssd and hdd?
https://linustechtips.com/topic/157951-my-pc-build-help/#findComment-2105389
Here you go, the all new haswell refresh, non overclockable, gtx 780, red color scheme, beatiful case, and most importantly under budget. Im not sure which brands sell things in tokyo, so just try to find a similar spec replacement if something is not sold by you.
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor ($219.99 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.94 @ OutletPC)
Motherboard: ASRock H97 PERFORMANCE ATX LGA1150 Motherboard ($107.86 @ Newegg)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1600 Memory ($169.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Disk ($139.99 @ Best Buy)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($54.43 @ OutletPC)
Video Card: MSI GeForce GTX 780 3GB TWIN FROZR Video Card ($477.99 @ SuperBiiz)
Case: NZXT H440 (Red/Black) ATX Mid Tower Case ($119.99 @ Amazon)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply ($59.99 @ Micro Center)
Total: $1470.15
(Generated by PCPartPicker 2014-05-27 11:04 EDT-0400)
https://linustechtips.com/topic/157951-my-pc-build-help/#findComment-2105396
Total: $1470.15
Everyone will make a different build for me but how can I choose which one to get? For example Asus vs MSI vs ASRock motherboards and etc
https://linustechtips.com/topic/157951-my-pc-build-help/#findComment-2105410
Having an ssd and a separate hdd is a much better configuration. Most sshds only come with 4-8gb of ssd memory on it that it uses for your most used applications, buying them separate will allow you more flexibility on which programs are on the ssd, and give you more ssd space. A standalone ssd will have much faster read and write speeds than an sshd too. Also, an ssd and hdd fit in your budget,
https://linustechtips.com/topic/157951-my-pc-build-help/#findComment-2105413
Because no SSHD has as much flash capacity as an actual SSD.
https://linustechtips.com/topic/157951-my-pc-build-help/#findComment-2105414
Pretty much all Z87 motherboards are going to be just as good, unless you really want some fancy features.
oops double post sorry
https://linustechtips.com/topic/157951-my-pc-build-help/#findComment-2105425
A lot of it is subjective, usually it comes down to looks honestly. First compare the specs of something you are comparing, if thry match up then get the lower priced one, or whichever one looks cooler to you. When it comes to picking pc parts, it is very important you are open to all brands because you will probably find that one brand doesnt have good pricing on everything and using different brands per item will usually save you money. If you have any questions feel free to ask, or you can message me :)
https://linustechtips.com/topic/157951-my-pc-build-help/#findComment-2105433
https://linustechtips.com/topic/157951-my-pc-build-help/#findComment-2105441
No problem, I think a lot of people here forget that there is a real person behind each profile and that shoving a build in their face probably wont help as much as explaining and answering questions.
Also I see Windows 8.1 Update and Pro Update whats the difference?
https://linustechtips.com/topic/157951-my-pc-build-help/#findComment-2105480
