Main points:
  • Budget: £250/300GBP
  • Based in the UK
  • Main games played would be CS2/GTA V/New CoD title if possible
Looking upgrade recommendations as i have an older system that id like to get back up and running.
Currently has:
  • I5-3570
  • Asus Strix GTX 970
  • 8GB DDR3 Ram ( I know this will be in dire need of being changed
Ideally for now id like to keep the GPU as its a tad out of budget and i know my main weak points are CPU/RAM etc. Its just been that long since ive looked into any of this and would appreciate help on the best idea for parts under the budget.
All help appreciated.
https://linustechtips.com/topic/1579453-upgrade-help/
For CPU: 12400F or 5600 are what I'd consider entry-level CPUs now, you could get a motherboard and memory within your budget (cooler is included in the CPU box).
You could try and push up to a 7500F/7600 bundle for future upgradability, but I think that would put you over your budget by £50 or so.
For GPU: the best you'd get for just over £300 would be a 6750 XT, but even a 6600 non-XT would be a big upgrade.
https://linustechtips.com/topic/1579453-upgrade-help/#findComment-16492655
Would you recommend sticking with Intel then? Had a lot of friends go AMD recently and wasnt sure whatd be the more cost effective and best performing option
https://linustechtips.com/topic/1579453-upgrade-help/#findComment-16492667
Either used Ryzen or some 11/12th gen Intel system, how is the entire PC spec wise?
current PC:
PC configs I used before:
https://linustechtips.com/topic/1579453-upgrade-help/#findComment-16492672
It doesn't matter, those CPUs (12400F/5600) perform within a % or two and cost about the same (~£100).
Availability of a motherboard with the features you want might even make the decision for you more than the CPU.
https://linustechtips.com/topic/1579453-upgrade-help/#findComment-16492678
4 hours ago, Elliott243 said:
Main points:
  • Based in the UK
Currently has:
  • I5-3570
PCPartPicker Part List
CPU: *Intel Core i5-12400F 2.5 GHz 6-Core Processor  (£98.98 @ Amazon UK)
CPU Cooler: *Deepcool AG400 75.89 CFM CPU Cooler  (£22.00 @ Computer Orbit)
Motherboard: *MSI PRO B760-P DDR4 II ATX LGA1700 Motherboard  (£114.99 @ Amazon UK)
Memory: *TEAMGROUP T-Force Vulcan Z 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (£58.49 @ CCL Computers)
Total: £294.46
Generated by PCPartPicker 2024-08-14 03:25 BST+0100
https://linustechtips.com/topic/1579453-upgrade-help/#findComment-16492763
