Budget (including currency): Around 1300$ with some wiggle room.
Country: US
Games, programs or workloads that it will be used for: Mostly going to be used for gaming. Some Destiny 2, COD, maybe the occasional modded Minecraft or Terraria.
Looking to run 1440p 144hz if I can. Not including peripherals, but some advice on what to look for in that regard would be appreciated as well. Here's my part list.
https://pcpartpicker.com/list/XvwT28
https://linustechtips.com/topic/1579439-first-pc-build-advice/
Seems really good, but this is a C tier PSU, which you should not get for a build at this cost. The adata xpg core reactor 850W costs slightly more, but is a good A tier power supply. I would also rather get the 7900 GRE, it has more VRAM, better performance and costs less
https://linustechtips.com/topic/1579439-first-pc-build-advice/#findComment-16492501
5 minutes ago, OddOod said:
You sure about that?
That's a different PSU, the GF A3 is a B tier unit
As for the actual built, it's pretty good. The only thing I'd want to change is the motherboard as it is absolutely terrible (it doesn't even support PBO, it's an A620 board masquarading as a B650 board), and for $5 more you can get a much better board with the ASRock B650M Pro RS.
https://linustechtips.com/topic/1579439-first-pc-build-advice/#findComment-16492509
10 minutes ago, MiszS said:
Oh yeah, I saw this, but didn't see that it's GF not GF3
lolol, both of us were wrong. RONO got it though. B tier is fine IMO
https://linustechtips.com/topic/1579439-first-pc-build-advice/#findComment-16492540
  Reveal hidden contents
Can vouch for the asrock b650m pro rs , Its a really nice board with alot of features for the price.
It also happens to boot a hell of alot faster than my MSI B650m-a gaming wifi with expo enabled.
CPU : Ryzen 7 7800X3D @ -30mv All core
CPU Cooler : Thermalright Frozen Prism 240mm AIO
Mobo : Asrock B650m Pro RS Wifi
Ram : 32GB (2X16GB) Lexar Ares 6000MHZ CL 28-36-36-68
GPU : MSI Gaming X Slim 4070Ti Super 16GB ( 308W PL +140 Core +1000 Memory )
Storage : 2TB Verbatim Vi5000 Gen 4 NVME
PSU : Thermalright TG-750w 80+ Gold ATX 3.0 PCIE 5.0
Case : Fractal Design Pop Mini MATX
Case Fans : 3 X Thermalright TL-C12C-S RGB
Monitor :27" Samsung Odyssey G5 2560 x 1440 180 HZ IPS
Keyboard : HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
https://linustechtips.com/topic/1579439-first-pc-build-advice/#findComment-16492560
5 minutes ago, MiszS said:
Why was your guess wrong though? Doesn't it say that every PSU equal or less than 1200W should count?
Thermaltake has a ton of PSUs starting with GF. This model is the "GF A3" model which would fall under B-tier.
https://linustechtips.com/topic/1579439-first-pc-build-advice/#findComment-16492562
How long does it take you to boot? I used it in a build, at it takes like 5 minutes to boot to bios, though I've got to still try the fixes I've found, it still seems quite long
https://linustechtips.com/topic/1579439-first-pc-build-advice/#findComment-16492565
The MSI board or the Asrock?
https://linustechtips.com/topic/1579439-first-pc-build-advice/#findComment-16492630
yeah the GF A3 speculative B tier unit,
but...
It's ATX 3.0, so it doesn't really matter what tier it is as long as it's not garbage.
This is faster:
PCPartPicker Part List
CPU: *AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($182.16 @ Amazon)
CPU Cooler: *Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  ($35.90 @ Amazon)
Motherboard: *ASRock B650M Pro RS Micro ATX AM5 Motherboard  ($134.99 @ Newegg)
Memory: Silicon Power XPOWER Zenith Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($84.97 @ Newegg Sellers)
Storage: *TEAMGROUP MP44L 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($105.99 @ Amazon)
Video Card: *ASRock Phantom Gaming OC Radeon RX 7900 XT 20 GB Video Card  ($689.99 @ Amazon)
Case: Lian Li A3-mATX MicroATX Mini Tower Case  ($69.98 @ Amazon)
Power Supply: Thermaltake Toughpower GF A3 - TT Premium Edition 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($85.99 @ Amazon)
Total: $1389.97
Generated by PCPartPicker 2024-08-13 18:10 EDT-0400
But if you need Nvidia for some reason or another, it's fine too.
Also the rest of the parts, the P3 Plus is not a bad SSD,
the Phantom Spirit is actually quieter than Peerless,
and the MB has stronger VRM.
current PC:
PC configs I used before:
https://linustechtips.com/topic/1579439-first-pc-build-advice/#findComment-16492658
Msi
About 45 seconds to get to the windows login screen.
https://linustechtips.com/topic/1579439-first-pc-build-advice/#findComment-16492949
My partner has been having this problem since we built their new rig with this exact mobo. SUPER annoying. Been hoping for a BIOS update to fix it but haven't gotten around to testing
https://linustechtips.com/topic/1579439-first-pc-build-advice/#findComment-16493247
