Question about argb plug
Solved by GuiltySpark_,
Just now, TurkishBTW said:Oh yea there is a main cable then a male connector is also attached to it to daisy chain things and I’m wondering if it’s fine to plug the led strip into it
I'm not quite following but its this simple for daisy chaining ARGB devices, assuming they have a male and female plug:
Motherboard/ARGB Controller <-> Device 1 <-> Device 2 <-> Device 3 and so on. There IS a limit to the number of LED's that can be controlled and the wattage but an LED strip and a couple fans should be fine.
