everytime i turn off my pc and then turn it back on (via the power button not on restart) within about an hour the gpu light on my motherboard stays on forever and my pc doesn’t display anything, everything is plugged in properly and i’ve reseated it many times but nothing works, but the gpu fans turn and the lights are on? this is rtx 4060 twin edge OC white edition. can someone help?
https://linustechtips.com/topic/1578699-gpu-not-work/
I'm confused is it staying on when you don't want it to be on or is your PC on and not displaying. It could be a driver issue so if you have integrated graphics in your cpu. If you don't I'd take it to a repair shop if you do then try to download the drivers for the 4060 using integrated graphics.
https://linustechtips.com/topic/1578699-gpu-not-work/#findComment-16486132
Update your GPU drivers and your motherboards BIOS if it isn't already up to date.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1578699-gpu-not-work/#findComment-16486153
