Bottleneck help
Solved by Skipple,
4 minutes ago, Gringoman420 said:I'm upgrading to 1440p UW and want to be able to play more competitive games at 180hz
The 5950x is a few years removed from being AMD's flagship processor. It's fine.
3 minutes ago, Gringoman420 said:And I found that it's a bottleneck when I searched on a bottleneck calculator
These are next to useless. Stop using them. They mean nothing.
My suggestion is to install your new GPU, then if there's something your machine isn't capable of, address it then.
