Help unplugging HD Audio
Solved by mariushm,
You should be able to just grab the heatshrink material (that round sleeve) around the cable and pull straight up. There's no locking mechanism or clip to lock the connector in place, it's like the USB 2.0 plugs. You can do it with the pc working if you want, not a problem.
The capacitors and everything related to sound works at 5v or less, so even if those capacitors would be live (which they aren't), you wouldn't feel anything.
