Quick question regarding using AIO cooler
Solved by Poinkachu,
5 minutes ago, Elam95 said:
AIO: H100I V2, upgrading to CPU: 5600x, no idea on AIO release date, I didn't assemble this pc or buy it new.
You will need to purchase additional bracket from Corsair.
If that no longer available, you most likely need a new cooler that supports AM4 socket
And btw, you don't really need an AIO to cool 5600x well.
I'd say just buy a good cheap air cooler, the heatsink lasts pretty much forever, the fans will stop working at some point but if the air cooler uses standard size fan and mounting, it can be replaced easily.
Unless you like the aesthetics AIO gives that is.
