Need Help With New Build
Solved by Silver Knight,
@srcds I'd personally go with first choice. With it you get a nice GPU, nice overclocking Mobo and a nice CPU for gaming, and after that i would save some money for 1600 x 900 monitor (270 would work a a lot better on that resolution than on 1080p!), but beware that AM3/+ is a pretty much a dead socket, so if you're not thinking of changing your CPU, Mobo and maybe RAM when you do the next upgrade, better go with option 2...
If you want immediate results, go with option 1, if you want to "future-proof" go with option 2!
