7 minutes ago, R3ap3r_999 said:
My question is how should I configure my fans, for now I have 2 intake one exhaust but I want to use the 2 at the top. Therefore my question is how should I configure it? The case is a fractal air pop mini
First of all, why? You want two intake fans. The current config should provide good positive pressure
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1574946-fans/#findComment-16451217
2 minutes ago, Blasty Blosty said:
Just buy 2 more fans, and put them at the top and keep the rest where they are.
no need fore more fans, simple as that
current PC:
PC configs I used before:
https://linustechtips.com/topic/1574946-fans/#findComment-16451221
If you want better air flow with the current config, you can start by mounting the fans on the inside, instead of the outside, like so:
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1574946-fans/#findComment-16451224
What CPU do you have ?
I'm pretty sure the DH-15 is pretty overkill all by istself, the 3 other fans helping air get out with positive pressure, so you don"t really need any more fans
If you really want to add them for looks put them top exhaust, but at slow speed to avoid negative pressure
https://linustechtips.com/topic/1574946-fans/#findComment-16451228
and air steal, let me borrow @DoctorNick's schematic:
  • the arrows roughly indicate airflow
  • as you can see, while the extra fans do help with heat being pushed out of the heatsink and case, they also partially steal the fresh air coming from the front fans
  • additionally you'd end up with 3 exhaust 2 intake, which would introduce negative pressure that is more likely to cause faster dust buildup compared to positive pressure you currently have
  • or in other words, you have enough fans, no need for more
current PC:
https://linustechtips.com/topic/1574946-fans/#findComment-16451741
I would put an intake on top right in front of the CPU.
In my Meshify C it was awesome.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1574946-fans/#findComment-16451877
Is that a Canadian flag behind the case?
If you're going to add fans to the top, you have different options for how to configure it, but keep in mind what was said previously by @freeagentabout more dust with more exhaust than intake. Get a rechargeable PC vac-blower to clean up the pesky dust.
Alternatively, as pointed out above by @PDifolco, set the fan curves for the top fans to be weaker, or use weaker fans there.
And, then you can take the idea of an intake fan above the CPU (also @freeagent), and even combine it with an exhaust in the other position on top. Try both combos to see which works better.
Or, keep it as is. 🙂
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1574946-fans/#findComment-16452849
Yes.
I trained a small gang of beavers to seek and destroy flagpoles small enough for them to take down, so I could collect my little prize 🙂
Edit:
Also, I am Canadian 🫡
https://linustechtips.com/topic/1574946-fans/#findComment-16452859
6 hours ago, freeagent said:
Yes.
Edit:
It is quite impressive that you were able to accomplish that, you brave Canuck! 🙂
https://linustechtips.com/topic/1574946-fans/#findComment-16453047
