Custom loop, starting only with CPU cooling
Solved by Createinator,
Anywhere between 150-300 Euro depending upon what kind of tubing and parts you buy. Stay away from hard tubing for your first attempt. I would suggest buying a kit like the EK L120 or EK L240 for your first custom loop. All the parts are 100% compatible and will fit most ATX mid tower and larger cases. Hope it helps! Best of Luck! ![]()
VirusDumb ·
Posted in Programming0 -
Jayraj ·
Posted in Power Supplies0 -
Airmack ·
Posted in Graphics Cards0 -
Kyle89 ·
Posted in Troubleshooting2 -
7
5
ken43 ·
Posted in Troubleshooting5 -
8
thedood2k ·
Posted in Power Supplies3
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
