Before I made the upgrade to my 24" BenQ I had two Samsung SyncMaster 940BW, after that I felt I could use them as side monitors.
Problem was I couldn't just undo the screws and turn the screen on to the mount
due to these metal mounts. As you can see there is hole for screws there. 75mm Vesa mount if I remember right.
post-81959-0-67910100-1401108564_thumb.j
Bam! Take them off!
post-81959-0-87300300-1401108176_thumb.j
And just made hole in the plastic and find some screws to fit it!
post-81959-0-41019400-1401108574_thumb.j
post-81959-0-07593400-1401108724_thumb.j
Final result with them on the desk! Everything is just right on!  :D
It's not a huge mod in any ways. But it made a huge difference at least for me!  :)
I might be psycho.  :huh:
https://linustechtips.com/topic/157431-samsung-mount-mod/
