Budget £1,300
Games, programs or workloads that it will be used for: Adobe After Effects
Hi im building a pc for the first time and i think its good but you guys just tell me if i should change anything because i dont really know much XD
PcPartPicker link:https://uk.pcpartpicker.com/list/MgrZbL
Just let me know if i should change something
(im buying from awd-it)
https://linustechtips.com/topic/1573313-my-first-pc/
The case includes 3x fans, I think? That should be enough for your build.
Alternatively: the Lian Li 216 also comes in white and with fans.
Edit: ignore the 14th gen stuff, I had a brain fart. Your motherboard is fine.
I don't think your board has flashback (says bootable since BIOS 3.04 in the CPU support for 14th gen), but MSI's B760M Gaming Plus is native 14th gen and has similar colour scheme. Alternatively, you could get the 12600K (GPU) or 12600KF (no GPU) which performs similar (a bit better actually) to the 13400 and would have no BIOS problem.
Your CPU doesn't need an AIO so a bit of a waste there really, the included cooler can manage it and a peerless assassin or phantom spirit for ~£35 (white versions are available) would easily manage it.
https://linustechtips.com/topic/1573313-my-first-pc/#findComment-16436349
You could get cheaper build if you don't care much about aesthetics, and if you don't care about upgrades much you could get 750W PSU, u should get better RAM
current PC:
PC configs I used before:
https://linustechtips.com/topic/1573313-my-first-pc/#findComment-16436355
Here's a board with better VRM's, ATX 3.0 psu, a cpu w/more more threads, faster RAM and a 2TB SSD.
PCPartPicker Part List
CPU: *Intel Core i5-13500 2.5 GHz 14-Core Processor  (£227.97 @ Amazon UK)
CPU Cooler: *Thermalright Peerless Assassin 120 SE WHITE ARGB 66.17 CFM CPU Cooler  (£34.13 @ Amazon UK)
Motherboard: *MSI PRO B760-P II ATX LGA1700 Motherboard  (£139.00 @ MoreCoCo)
Memory: *TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (£104.30 @ Amazon UK)
Storage: *Lexar NM710 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£112.49 @ CCL Computers)
Video Card: Zotac GAMING AMP GeForce RTX 3060 12GB 12 GB Video Card  (£299.99 @ AWD-IT)
Case: *Phanteks XT PRO ULTRA ATX Mid Tower Case  (£68.99 @ Overclockers.co.uk)
Power Supply: *MSI MAG A750GL PCIE5 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£96.98 @ Ebuyer)
Operating System: Microsoft Windows 11 Home OEM - DVD 64-bit  (£103.94 @ Overclockers.co.uk)
Total: £1187.79
Generated by PCPartPicker 2024-06-11 21:48 BST+0100
A better look at those components.
https://www.msi.com/Motherboard/PRO-B760-P-II/Overview
https://www.intel.com/content/www/us/en/products/sku/230580/intel-core-i513500-processor-24m-cache-up-to-4-80-ghz/specifications.html
https://www.tomshardware.com/reviews/thermalright-peerless-assassin-120-se
https://www.techpowerup.com/review/lexar-nm710-1-tb/
https://www.msi.com/Power-Supply/MAG-A750GL-PCIE5
https://phanteks.com/product/xt-pro-ultra-white/
https://linustechtips.com/topic/1573313-my-first-pc/#findComment-16436356
