Hey all. I need to get myself a powered USB hub. It does not jeed data. I am looking for one that just plugs into the wall and not the computer for charging pc accessories. I need roughly 5 of each usb A and usb C.
also not looking to spend more than like 80 CAD. Any suggestions appreciated.
https://linustechtips.com/topic/1571974-powered-usb-hub/
I'm happy with this, Type A only. High quality.
https://www.amazon.com/gp/product/B075NMVGP7
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1571974-powered-usb-hub/#findComment-16424042
I have three of these Anker Charging Stations, they are A only though.
I've since replaced them with some Anker GAN versions which have A and C ports, but only 2 of each.
I would keep in mind that you can also just use a regular powered USB hub as well if you find one that has the ports you like. I did this for many years, as I prefer slow charging my devices. I still do this at times I just leave the hubs on to charge things.
https://linustechtips.com/topic/1571974-powered-usb-hub/#findComment-16424323
I would recommend this. Sabrent is a reliable brand.
https://www.amazon.com/Sabrent-Family-Sized-Charger-Technology-AX-TPCS/dp/B00OJ79UK6/
You don't necessarily want to use a USB-C port to charge a USB-C device.
I've encountered several USB-C devices that refuse to charge because the device-maker was too cheap to build to the device with the necessary $0.01 components (resistors?) to enable proper USB negotiation. The workaround is that USB-A to USB-C cables bypass the negotiation and force the power through.
It's definitely a pain in the ass when a fancy $100 Anker USB charger can't charge a damn $5 USB light because there's no negotiation occurring -_-
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
https://linustechtips.com/topic/1571974-powered-usb-hub/#findComment-16424332
The only issue is, for some of my devices i only have a cord that plugs into usb c. Unless i get an adapter
https://linustechtips.com/topic/1571974-powered-usb-hub/#findComment-16427456
A pack of USB-C to USA-A adapters is really cheap. Same with getting C to A cables.
https://linustechtips.com/topic/1571974-powered-usb-hub/#findComment-16427505
